goldrush49's avatar
goldrush49
MR60, not saving changes after reboot
When I make changes in the routerlogin.net screen, I hit save and it updates the settings and everything looks good. When I reboot the router though, it reverts the settings back to what it was befor...
  • Born2roam's avatar
    Born2roam
    Mar 23, 2024
    I have an update to my reported fix from last year:  Restoring an immediately saved configuration appeared to work initially but after my next weekly reboot, the modem settings reverted back!  When that happened again, I decided to cut bait and purchased a replacement "other" brand modem.  The new modem has been running flawlessly since.  Problem solved.
