goldrush49
Sep 13, 2023Aspirant
MR60, not saving changes after reboot
When I make changes in the routerlogin.net screen, I hit save and it updates the settings and everything looks good. When I reboot the router though, it reverts the settings back to what it was befor...
- Mar 23, 2024
I have an update to my reported fix from last year: Restoring an immediately saved configuration appeared to work initially but after my next weekly reboot, the modem settings reverted back! When that happened again, I decided to cut bait and purchased a replacement "other" brand modem. The new modem has been running flawlessly since. Problem solved.
michaelkenward
Sep 13, 2023Guru - Experienced User
One question seeking clarification, what is the modem/gateway/ONT between the router and the Internet?
I ask because it can interfere with the smooth operation of the browser graphical user interface (GUI).
goldrush49
I was directly wired into the MR60, which at that time, it was not connected to the ISP modem and not connected to the internet.
- michaelkenwardSep 13, 2023Guru - Experienced User
Tried connecting it to modem to complete the network?
- goldrush49Sep 13, 2023Aspirant
Yes, thats how it was connected initially but when I started to have problems, I was isolating it just to the MR60 and removed it from the network to figure out why I couldn't reset it back to factory settings and it wasn't actually applying any of the setting changes.
Is it a new router?
May be a dud that needs replacing.
