goldrush49
Sep 13, 2023Aspirant
MR60, not saving changes after reboot
When I make changes in the routerlogin.net screen, I hit save and it updates the settings and everything looks good. When I reboot the router though, it reverts the settings back to what it was befor...
- Mar 23, 2024
I have an update to my reported fix from last year: Restoring an immediately saved configuration appeared to work initially but after my next weekly reboot, the modem settings reverted back! When that happened again, I decided to cut bait and purchased a replacement "other" brand modem. The new modem has been running flawlessly since. Problem solved.
Born2roam
Nov 12, 2023Aspirant
I am experiencing exactly the same problem. Goldrush49 did not respond to Furrye38's resolution comments. Before I undertake a complete factory refresh of the router, it would be nice to know if worked. Has anyone else experienced this?
michaelkenward
Nov 12, 2023Guru - Experienced User
If you are worried about wiping out your carefully created configuration, you can save a copy of it.
Then if the reset doesn't clear up your issue you can restore the settings.
Never a wise assumption. Can you answer all the previous questions for Born2roam with the same answers? For example, what is the modem/gateway/ONT between your router and the Internet?
If it is "exactly the same problem" then the reset won't do anything anyway. In which case you will not have lost anything.
- Born2roamNov 12, 2023Aspirant
Motorola 24x8 cable modem, model MB7621
