goldrush49
Sep 13, 2023Aspirant
MR60, not saving changes after reboot
When I make changes in the routerlogin.net screen, I hit save and it updates the settings and everything looks good. When I reboot the router though, it reverts the settings back to what it was befor...
- Mar 23, 2024
I have an update to my reported fix from last year: Restoring an immediately saved configuration appeared to work initially but after my next weekly reboot, the modem settings reverted back! When that happened again, I decided to cut bait and purchased a replacement "other" brand modem. The new modem has been running flawlessly since. Problem solved.
michaelkenward
Nov 12, 2023Guru - Experienced User
Born2roam wrote:
Before I undertake a complete factory refresh of the router, it would be nice to know if worked.
If you are worried about wiping out your carefully created configuration, you can save a copy of it.
Then if the reset doesn't clear up your issue you can restore the settings.
Born2roam wrote:
I am experiencing exactly the same problem.
Never a wise assumption. Can you answer all the previous questions for Born2roam with the same answers? For example, what is the modem/gateway/ONT between your router and the Internet?
If it is "exactly the same problem" then the reset won't do anything anyway. In which case you will not have lost anything.
Born2roam
Nov 12, 2023Aspirant
Motorola 24x8 cable modem, model MB7621
