goldrush49
Sep 13, 2023Aspirant
MR60, not saving changes after reboot
When I make changes in the routerlogin.net screen, I hit save and it updates the settings and everything looks good. When I reboot the router though, it reverts the settings back to what it was befor...
- Mar 23, 2024
I have an update to my reported fix from last year: Restoring an immediately saved configuration appeared to work initially but after my next weekly reboot, the modem settings reverted back! When that happened again, I decided to cut bait and purchased a replacement "other" brand modem. The new modem has been running flawlessly since. Problem solved.
Born2roam
Nov 12, 2023Aspirant
I discovered a way to resolve this problem. Immediately after making the router configuration change/update, go to Advanced | Administration | Backup Settings and create a backup of the new configuration. Then restore that configuration to the router immediately. After testing with several reboots, the new config changes now remain in place.
michaelkenward
Nov 12, 2023Guru - Experienced User
Not recommended. That has a habit of bringing back any bugs that the reset cleared.
But, if it works for you, great.
- Born2roamNov 12, 2023Aspirant
Yes I agree, it works as a temporary solution. I needed to resolve the issue for some important config changes that just wouldn't stick and kept reverting to the previous settings every time the router was power cycled.
Your point about carrying a bug forward is a concern. I plan to do some additional testing to see if config mods continue to revert to the prior setting after a reboot again. If so, there is a bug somewhere and when I get the time I will follow the steps above to factory reset the router and rebuild the config. Thanks for your response.
