goldrush49
Sep 13, 2023Aspirant
MR60, not saving changes after reboot
When I make changes in the routerlogin.net screen, I hit save and it updates the settings and everything looks good. When I reboot the router though, it reverts the settings back to what it was befor...
- Mar 23, 2024
I have an update to my reported fix from last year: Restoring an immediately saved configuration appeared to work initially but after my next weekly reboot, the modem settings reverted back! When that happened again, I decided to cut bait and purchased a replacement "other" brand modem. The new modem has been running flawlessly since. Problem solved.
Farouk2024
May 21, 2024Aspirant
Have you had any luck resolving this issue? NetGear replied to my 1-star review asking me to connect with support, which I can't do because I don't have a valid support contract/warrenty, and NetGear is asking me to pay to buy support, which is going to happen over my dead body. If NetGear hasn't noticed this issue already, then I'd be wasting more money on the extremely slim chance that they fix it!
