BR1337
Jan 18, 2024Aspirant
MR60 of MK63 not connecting to internet (solid orange/amber light)
Hello, I have a MR60 in the MK63 mesh system that refuses to connect to the internet. Here are the details: - Solid orange/amber light on router - Blue lights on both of the satellites ...
michaelkenward
Jan 18, 2024Guru - Experienced User
What modem/ONT/gateway sits between the router and the Internet?
I have not been able to get anything other than this orange light.
The good news is that the LED isn't pulsing, which would warn of corrupt firmware.
- BR1337Jan 18, 2024Aspirant
What do you mean by gateway between the router and internet? As in the modem? The modem is a Surfboard SB6141.
Also to be honest corrupted firmware is easier to deal with, this kind of stuff is a pain to diagnose.
- FURRYe38Jan 18, 2024Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
The ISP needs to make sure there is good internet services and signal up to the ISP modem. Something they need to check on. Also that model modem is getting up in age. Maybe time for a newer model motorola modem. I had the SB6121 years ago. Was a good modem for that time.
- michaelkenwardJan 19, 2024Guru - Experienced User
Yes, gateway is often used to describe a modem with extra functions, such as support for voice telephony or an integrated router.
.Your SB6141 is a plain cable modem. So not router component to mess up your network.
