zettabyte72
Apr 07, 2024Aspirant
mr60 port forwarding issues
ive recently switched to the mr60 mesh system and im trying to port forward a system for a game server. but for whatever reason the mr60 router is just not having it. i know that my system is configu...
schumaku
Apr 10, 2024Guru - Experienced User
Don't worry, it hast it - certainly as long as the MR60 is in Router mode:
ADVANCED > Advanced Setup > Port Forwarding/Port Triggering
Usually consulting the fine documentation helps: https://www.netgear.com/support/product/mr60#docs
Nighthawk Mesh WiFi 6 System Router Model MR60 and Satellite Model MS60 User Manual p.126 ff.
Correct Server LAN IP address in place?
Correct protocol and port configured?
Double-checked the ISP does assign a route-able IP address to your MR60? (Advanced Home - Internet Port - IP Address) - an not a Carrier-Grade-NAT IP Address or Private Internet RFC 1918 Address assigned?
No firewall rules prohibiting access the server LAN IP from the wild Internet?
UPnP enabled, and some unwanted UPnP-configured port forwarding rules in place?
ADVANCED > Advanced Setup > UPnP.
- zettabyte72Apr 12, 2024Aspirant
lol, not what i meant by not having it. guess thats local slang or something. ive followed the guides and manuals like the one youve sent and i have the option in the router and have it all setup correctly but its still not working. from the ip to the port to the firewall and already delt with upnp. still not visible to the internet. since someone asked i have a spectrum supplied modem, which ever one they give you for gigabit. its not a combo unit, just modem. is there a known issue with spectrum and netgear stuff? i dont see why tplink would work without issue but not netgear with neither having anything to do with the hardware spectrum supplied. havent had a free day to test having the tplink as the router again, so if i get to that ill leave a note on if that works.
either way thank you for the responses! greatly appreciated! i dont have as much time to tinker as i used to so i might go back to old reliable when given the chance
- FURRYe38Apr 17, 2024Guru - Experienced User
