ShowtimeFox123
Jul 20, 2024Aspirant
(MR60) Port not opening/Can't port forward on MR60
I have always been brushing this problem aside for the past 3 years now, but I'm now finally at that point where I'm wanting to fix this problem. I've been at this for several days frustratingly tryi...
Jul 25, 2024Guru - Experienced User
Most games don't need any port forwarding configurations if you have uPnP enabled on the MR.
If you set any PF configurations, then be sure to disable uPnP on the MR.
- ShowtimeFox123Jul 27, 2024Aspirant
I do not know what the MFR is, but the model number on the modem is "XS-010X-Q" and the ONT is "3FE49331AAAB". It's a NOKIA brand.
I'm aware that most games don't require port forwarding nowadays, but there are some exceptions to some games- let's say for example Minecraft (If you're hosting a server through your own network. I'm aware there's other methods to host a server through Minecraft).
- FURRYe38Jul 30, 2024Guru - Experienced User
So no router built in to the ONT so your good there.
If you set any PF configurations on the MR, then be sure to disable uPnP on the MR.
