Mikeobrien
Oct 20, 2022Follower
MR60 power adaptor
My girlfriends cat chewed through my MR60 power adaptor & I’m trying to get a replacement for it. Unfortunately Netgear makes it impossible to get in touch with anyone that can help me. I find it v...
- Oct 20, 2022
How bad is the cable. Most could be repaired, if stripped and twisted together and taped.
Look on Amazon?
michaelkenward
Oct 20, 2022Guru - Experienced User
Netgear does not sell replacement power adapters. Any generic transformer will work, as long as it has the right volts, enough amps and a tip with the right (+/-) polarity and dimensions. (Look at the label on your device or the old adapter.)
These things are pretty common, so first check to see if you have something compatible lying around.
Look at the label on the device itself. The manual says 12V, 1A DC output the data sheet says 12V/1.5A power adapters.
Some web stores will even claim compatibility with Netgear devices. There may even be a retail outlet near you.
Some generic adapters come with a set of tips that will fit a range of different devices.
Generic adapter
