Jeffro4lif
Sep 27, 2024Aspirant
MR60 Router Only Connects limited devices to WIFI but not to Internet after Power Outage
MR60 Firmware Version V1.1.7.134_2.0.65, 2 Satellites with latest firmware as well. A little over a week ago, we had a brief 20 minute power outage. Upon powering back up, we had no internet connec...
Sep 27, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Does the front LED on the MR turn AMBER when this happens? Should be BLUE. Same for MS, they should be blue as well after a short period of time when they come online and connect to the MR.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://kb.netgear.com/23783/How-do-I-change-the-wireless-channel-on-my-NETGEAR-router
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
- Jeffro4lifSep 29, 2024Aspirant
Yes the lights will turn blue. As I mentioned in another reply, I changed the password back to the original after adding some devices back and it did the same thing. It only connects a limited number then nothing gets an IP and when assigning a static IP i can talk to the router but not internet.
- FURRYe38Sep 30, 2024Guru - Experienced User
Sounds like a possible interoperability issue between the MR and your ISP modem/ONT. May not be fully connecting properly during a power outage and everything comes back ON.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
