Jeffro4lif
Sep 27, 2024Aspirant
MR60 Router Only Connects limited devices to WIFI but not to Internet after Power Outage
MR60 Firmware Version V1.1.7.134_2.0.65, 2 Satellites with latest firmware as well. A little over a week ago, we had a brief 20 minute power outage. Upon powering back up, we had no internet connec...
Jeffro4lif
Sep 29, 2024Aspirant
Yes the lights will turn blue. As I mentioned in another reply, I changed the password back to the original after adding some devices back and it did the same thing. It only connects a limited number then nothing gets an IP and when assigning a static IP i can talk to the router but not internet.
Sep 30, 2024Guru - Experienced User
Sounds like a possible interoperability issue between the MR and your ISP modem/ONT. May not be fully connecting properly during a power outage and everything comes back ON.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
