ABG4280
Mar 28, 2022Aspirant
MR60 Satellite FW corrupted, will not connect
I've owned the MK63 mesh system (MR60 with two MS60 satellites) for over 1 year with no major issues. Recently upgraded the FW using the app to v1.1.6.122. The FW pushed through the MR and one of the...
- Apr 01, 2022
Thanks for the input. Tried refreshing using PC and failed, did it on a Mac and took 2 minutes. The odd part was that during the re-flashing, the light of the device is supposed to be "Amber". Instead, it was slow pulsing white, which meant issues with the FW.
For reference:
Fast pulsing white = attempting to sync to router
Pulsing Amber (or Slow pulsing white) = firmware corrupted, no connectivity
Solid blue = synced to router, connected to the internet, all good
Solid Amber = unable to connect to the internet or synced (offline)
ABG4280
Mar 29, 2022Aspirant
Further UPDATE:
I found instructions on how to update the firmware for NETGEAR routers using TFTP. I downloaded the latest firmware from the MS60 support page and then I followed these instructions:
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
However, the firmware update stalled at about 40% and stopped. The satellite continued to pulse the white light at all times.
Any suggestions/recommendations?
- plemansMar 29, 2022Guru - Experienced User
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash - EternalStudentMar 29, 2022Apprentice
I'd be curious to hear what the various light colors mean. I typically see amber while booting and blue when mostly functional (router has IP, and satellite sees router). I haven't tried looking during a flash.
If you can't get it to work after a few tries (and that other program), I'd try the older flash again. Not try to upgrade during the recovery. Just grasping at anything else that might work and be different...
- ABG4280Apr 01, 2022Aspirant
For reference:
