ABG4280's avatar
ABG4280
MR60 Satellite FW corrupted, will not connect
I've owned the MK63 mesh system (MR60 with two MS60 satellites) for over 1 year with no major issues. Recently upgraded the FW using the app to v1.1.6.122. The FW pushed through the MR and one of the...
  • ABG4280's avatar
    ABG4280
    Apr 01, 2022
    Thanks for the input. Tried refreshing using PC and failed, did it on a Mac and took 2 minutes. The odd part was that during the re-flashing, the light of the device is supposed to be "Amber". Instead, it was slow pulsing white, which meant issues with the FW.
    For reference:
    Fast pulsing white = attempting to sync to router
    Pulsing Amber (or Slow pulsing white) = firmware corrupted, no connectivity
    Solid blue = synced to router, connected to the internet, all good
    Solid Amber = unable to connect to the internet or synced (offline)
