MFL100
Jun 22, 2022Aspirant
MR60 Satellite Orange Light Strange
Often, when one of my satellites shows an orange light, if I wave my hand near it, the light turns blue. What is happening?
Jun 22, 2022Guru - Experienced User
I don't show an orange for the satellites but it does have amber, blue, white.
If its amber, it doesn't have a connection to the router.
Maybe something is causing interference between the router/satellite and you moving between the 2 causes it to change? (maybe switches to a different channel)
