Bukid
May 17, 2024Aspirant
MR60 Satellite Stuck at 100mpbs
If connected to the main router, then I am able to get 400-500 mbps. However when I connect to the MRS satellite, then I get only up to 100mbps. I’ve rebooted, reset, etc. Doesn’t work.
Bukid
May 18, 2024Aspirant
The modem is a NETGEAR CM1100
May 23, 2024Guru - Experienced User
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between MR 📡 and MS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
