aandmhill
Feb 02, 2021Tutor
MR60 Satellite won't connect
After doing an update, 1 of 2 satellites wont connect. Tried customer support, but no help there. System is less than 30 days old and was functioning great until the update. App shows zero firmware...
- Sep 28, 2021
You need to update the MS before updating the MR. Keep this in mind for future updates.
What you need to do is factory reset the MS. Wire connect a PC to the 1st satellite. Already have the most current FW version files downloaded on to this PC.
Wire connect 1 PC to the back of the MS. Factory reset the MS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the MR.
LesBaz
Feb 03, 2021Aspirant
Right there with you after this firmware update to 1.0.6.110 on my MK63 system, one satellite doesn't show connected in the Nighthawk app and the devices connected to that one satellite never list out either. I have found that my devices are all connecting to my network under the groups 'Devices' section of the app, and I know that all the router and satelites are working as some of my devices wouldn't connect if the satellite was really down. I use a stand alone wifi scanner and I see my router and both satellite SSID's just fine. After this firmware update I have better results using the web interface to manage my system, but even that isn't perfect and the app was much easier to use. Hopefully Netgear fixes this soon as it is really frustrating managing my network like this right now. If this goes on much longer I may try to manually rollback the firmware to the prior version.
aandmhill
Feb 03, 2021Tutor
I have a few devices that show up as 'wired' now, which is odd as one of them is a phone. So you're saying even though it doesnt show up as 'working' in the app, it really IS working? I'm not savvy at all with things like this, but it would be nice if something resembling support was actually available. Is there a way to confirm its still working?
