aandmhill
Feb 02, 2021Tutor
MR60 Satellite won't connect
After doing an update, 1 of 2 satellites wont connect. Tried customer support, but no help there. System is less than 30 days old and was functioning great until the update. App shows zero firmware...
- Sep 28, 2021
You need to update the MS before updating the MR. Keep this in mind for future updates.
What you need to do is factory reset the MS. Wire connect a PC to the 1st satellite. Already have the most current FW version files downloaded on to this PC.
Wire connect 1 PC to the back of the MS. Factory reset the MS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the MR.
mattpierce12
Apr 13, 2021Initiate
I spent an entire workday attempting to fix this error to no avail. I restarted, reconfigured, and rolled back updates to no avail. The product was returned to Costco and exchanged for a Google Mesh system.
