aandmhill
Feb 02, 2021Tutor
MR60 Satellite won't connect
After doing an update, 1 of 2 satellites wont connect. Tried customer support, but no help there. System is less than 30 days old and was functioning great until the update. App shows zero firmware...
- Sep 28, 2021
You need to update the MS before updating the MR. Keep this in mind for future updates.
What you need to do is factory reset the MS. Wire connect a PC to the 1st satellite. Already have the most current FW version files downloaded on to this PC.
Wire connect 1 PC to the back of the MS. Factory reset the MS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the MR.
DayDreamin
Mar 16, 2021Initiate
I recently purchased an MK63 system (MR60 with two MS60 satellites). Setup went smooth, and after a bit I dropped connection to one satellite. Tried everything, including a factory reset. No luck. Finally downgraded the firmware to 1.0.4...something (one back) and everything worked! Next day, one satellite dropped. Turns out there is an Auto Update feature. I turned that off Auto Update and downgraded the firmware again, and the satellite picked right up. Netgear needs to fix their firmware.
Jgarcia17
Apr 28, 2021Aspirant
How do I downgrade firmware?
- IainMurrayApr 29, 2021Tutor
Hi you need to download from the Netgear support site and then install using the browser login under the Advanced/Administration/Router Update section. Pretty easy to be honest
