mercat68
Jan 13, 2022Aspirant
MR60 Satellites showing as offline in phone app after updating firmware
Hi. I upgraded the firmware of my MR60 Mesh system today from 1.0.6.116 to 1.1.6.122 (manually downlaoded and installed). Since the upgrade, the Nighthawk app on my iPhone is showing the two satellit...
Jan 13, 2022Guru - Experienced User
Please post a screen capture of what your seeing.
Has a power off of the ISP Modem, MR and MS for 1 minute or longer then back ON with the modem, MR then MS in that order and wait for all to be ready, then connect using the NH app change the status seen there?
mercat68
Thanks. I'll try that in the morning. Here's a screen shot of the NH app page showing the grayed-out satellite units.
- FURRYe38Jan 13, 2022Guru - Experienced User
On the home page of the NH app, do you have a tile for Network Map? If so, whats seen there? Please post a screen capture.
- mercat68Jan 13, 2022Aspirant
Not sure what you mean by title. Here's screen capture of the page.
- mercat68Jan 14, 2022Aspirant
Just to follow up, I tried the power off/power on routine in the proper order this morning and there's no difference in what the NH app reports. It's still showing the satellites as offline. See attached photo of one satellite's page in the network map reporting that "no connected device found."
