NeoMatrix835
Feb 12, 2022Follower
MR60 Satellites suddenly disconnected; can't factory reset either of them, both white flashing light
The subject mainly says it all. Everything was working fine since the initial setup last June 2021. It is February 2022 and I woke up this morning to the following... - The router itself was on ...
Feb 12, 2022Guru - Experienced User
try hardwiring the satellite into the router and updating its firmware while hardwired in.
You can also try to sync them via that method
