Bakerson0311
Nov 18, 2022Aspirant
MR60 satellites won't connect after router is rebooted
I had a problem about a month ago where the two satellites would not connect to the router after rebooting. After doing a factory reset and doing a lot of fiddling with the reset buttons, I was fina...
Nov 18, 2022Guru - Experienced User
Was the MS FW updated before the MRs FW was updated?
How was the system updated? Automatically from NG or did you manually update?
MInes working so far.
