jlopez91901
Feb 12, 2022Follower
MR60 Separating 2.4Ghz and 5.Ghz
I am trying to figure out how to separate my 2.4Ghz and 5Ghz bands. My TV supports both but i need it to lock onto the 2.4Ghz band so i can have it connect to my phone and smart home assistant. Mode...
MNSnowman
Feb 18, 2022Tutor
Same issue here- I purchased the Nighthawk MR60 mesh system, and while setup was a breeze with the app, my wireless Brother HL-2170W printer is now a paperweight. Created a guest 2.4Ghz network on the router, and even though I loged on to that network with the laptop, it still does not "see" the printer. Support tickets open with both NetGear and Brother, but still nothing. Thought I'd try the Community....
Modem is an older NetGear CM500. Was using the NetGear 750 Dual Band Router, which worked perfectly, but had trouble pushing WiFi to all corners of the house. Firmware on the MR60 is up to date.
What is frustrating is the MR60 clearly connects on the 2.4Ghz band (see photo)- but of course defaults to the 5Ghz band. Why doesn't the MR60 see the printer on this network??
Feb 18, 2022Guru - Experienced User
Half the time these devices don't see the network because their drivers aren't updated/maintained properly for the AX spec. Try disabling AX on the 2.4ghz.
