jlopez91901
Feb 13, 2022Follower
MR60 Separating 2.4Ghz and 5.Ghz
I am trying to figure out how to separate my 2.4Ghz and 5Ghz bands. My TV supports both but i need it to lock onto the 2.4Ghz band so i can have it connect to my phone and smart home assistant. Mode...
Feb 18, 2022Guru - Experienced User
I have that same hl-2170w printer. It does have an ethernet port. you could hardwire it into the router or satellite
MNSnowman
Feb 18, 2022Tutor
Seems worth a try. I'll need a longer ethernet cable for the permanent printer location, but for now, I can temporarily relocate the printer. Just spent 90 FRUSTRATING minutes on the phone with "support"....
- MNSnowmanFeb 25, 2022Tutor
To the community:
I have hardwired the router to the printer with an ethernet cable, reloaded the original installation disk and rebooted everything. I now have a functional printer from any connected device, and since the cable is hidden, no unsightly cables to belie the installation.
I thank each of you for your ideas and support! Bravo Zulu!
MNSnowman
