jlopez91901
Feb 12, 2022Follower
MR60 Separating 2.4Ghz and 5.Ghz
I am trying to figure out how to separate my 2.4Ghz and 5Ghz bands. My TV supports both but i need it to lock onto the 2.4Ghz band so i can have it connect to my phone and smart home assistant. Mode...
MNSnowman
Feb 18, 2022Tutor
Same issue here- I purchased the Nighthawk MR60 mesh system, and while setup was a breeze with the app, my wireless Brother HL-2170W printer is now a paperweight. Created a guest 2.4Ghz network on the router, and even though I loged on to that network with the laptop, it still does not "see" the printer. Support tickets open with both NetGear and Brother, but still nothing. Thought I'd try the Community....
Modem is an older NetGear CM500. Was using the NetGear 750 Dual Band Router, which worked perfectly, but had trouble pushing WiFi to all corners of the house. Firmware on the MR60 is up to date.
What is frustrating is the MR60 clearly connects on the 2.4Ghz band (see photo)- but of course defaults to the 5Ghz band. Why doesn't the MR60 see the printer on this network??
fredboer
Feb 24, 2022Star
I struggled to connect my brand new Epson ET-3830. Had several conversations with tech support for both printer and router. Here are things that were suggested:
Do all the firmware update... and...
1. Manually set channel for 2.4Ghz. (Auto may use channels that conflict/don't work. Try 1, 6, 11)
2. Set a reserved IP address for the printer.
3. Turn off AX features.
4. Disable Implicit Beamforming
None of these worked.
Then, when talking to Netgear tech on an unrelated issue (Documentation says you can disable MU-MIMO, but you can't), the tech suggested turning off SSID Broadcast (under 5Ghz settings). I can't remember why this might help (I think he said something about this forcing connections to *start* with 2.4Ghz), but I did this and it seemed to work. Of course, this makes your network "hidden" so you have to be ok with that...
FWIW.. Good luck!
Fred
- FURRYe38Feb 24, 2022Guru - Experienced User
- fredboerFeb 24, 2022Star
I suppose so! Thanks for that suggestion. For me, I didn't care that the network was hidden. Also, if the printer *did* still disconnect, leaving the wifi network hidden means that that printer can re-connect automatically without issues. But yes, if you didn't want a hidden network, for sure!
Cheers!
Fred
- plemansFeb 24, 2022Guru - Experienced User
once you have the printer connect, usually you can turn the 5ghz ssid broadcast back on.
