jlopez91901
Feb 13, 2022Follower
MR60 Separating 2.4Ghz and 5.Ghz
I am trying to figure out how to separate my 2.4Ghz and 5Ghz bands. My TV supports both but i need it to lock onto the 2.4Ghz band so i can have it connect to my phone and smart home assistant. Mode...
Feb 24, 2022Guru - Experienced User
fredboer
Feb 24, 2022Star
I suppose so! Thanks for that suggestion. For me, I didn't care that the network was hidden. Also, if the printer *did* still disconnect, leaving the wifi network hidden means that that printer can re-connect automatically without issues. But yes, if you didn't want a hidden network, for sure!
Cheers!
Fred
