jlopez91901
Feb 12, 2022Follower
MR60 Separating 2.4Ghz and 5.Ghz
I am trying to figure out how to separate my 2.4Ghz and 5Ghz bands. My TV supports both but i need it to lock onto the 2.4Ghz band so i can have it connect to my phone and smart home assistant. Mode...
Feb 13, 2022Guru - Experienced User
No, the MR60 doesn't have that option.
Your phone/home assistants should still work if the router is on 5ghz and your other devices aren't.
Whatt modem/gateway do you have?
What firmware is on the router?
What is actually happening in detail?
GADGET2002
May 11, 2022Aspirant
There's been an update (MAY2022) to the MS60 software which now does allow splitting 2.4ghz and 5ghz.
