Amaddog
Oct 16, 2021Aspirant
MR60 setup lan cable not detected
When setting up the router I get cable not detected several times. Once it did recognized the cable and said no internet. The next time I got no cable connected again. I use the same cable and modem o...
Oct 16, 2021Guru - Experienced User
Be sure your ethernet adapter networking settings on your PC are set for automatic and not static.
Are you trying to access 192.168.1.1 or 10.0.0.1? Try both?
- AmaddogOct 16, 2021AspirantI am using my phone and the Netgear app to set up. The router worked fine for many months then a few days ago I discovered no wifi signal and have been trying to set back up ever since.
- FURRYe38Oct 16, 2021Guru - Experienced User
Try a wired Pc or laptop if you have one.
Press the reset button in back for 15 seconds then release.Review the online installation guide for help and information on how to set it up using a mobile device or wired computer.
- AmaddogOct 16, 2021AspirantI have done all of that and twice with customer support. Whether I use a laptop of phone app I get the same error to check cable connection from modem. I have noticed all of the posts on this subject never seem to be resolved.
