Amaddog
Oct 16, 2021Aspirant
MR60 setup lan cable not detected
When setting up the router I get cable not detected several times. Once it did recognized the cable and said no internet. The next time I got no cable connected again. I use the same cable and modem o...
Amaddog
I am using my phone and the Netgear app to set up. The router worked fine for many months then a few days ago I discovered no wifi signal and have been trying to set back up ever since.
Oct 16, 2021Guru - Experienced User
Try a wired Pc or laptop if you have one.
Press the reset button in back for 15 seconds then release.
Review the online installation guide for help and information on how to set it up using a mobile device or wired computer.
- AmaddogOct 16, 2021AspirantI have done all of that and twice with customer support. Whether I use a laptop of phone app I get the same error to check cable connection from modem. I have noticed all of the posts on this subject never seem to be resolved.
- FURRYe38Oct 16, 2021Guru - Experienced User
Has a power off of the modem and MR for 1 minute then back ON with the modem first then MR lastly been performed?
Ensure a good quality LAN cable is used between the modem and router? CST6 is recommended.
- AmaddogOct 16, 2021AspirantThe cable I am using and the two others I have tried all work with direct connection to my laptop and with my old R7000 wifi router I am using right now. The cables are fine. I have followed your suggested power on and off in exact order many times and did this with the customer support rep on the phone. I can connect to the MR60 mesh wifi signal, but cannot get through set up since no cable is detected.
