FunTwo
Aug 02, 2021Star
MR60 showing orange light
I brought the refurbed model with one satellite speaker. The router had the orange light on vs the blue light on the satelite. The MAC address was starting with a 10, which the ISP tech told me "it...
Aug 03, 2021Guru - Experienced User
What actual modem/gateway is it connected to?
FunTwo
Aug 03, 2021Star
Connected to the ISP provided modem for the fiber line. I have not access to that.
The tech said everything looks good, but the MAC address for the router was starting with 10. He called that "bridge mode". So very confused at that, cuz at that point, I had already factory resetted the router at least twice.
- plemansAug 03, 2021Guru - Experienced User
What actual gateway is it?
It wouldn't be the first time I've seen the tech just saying stuff to get out of a home.
if its starting with a 10. its usually detecting another router running and switching from the default 192.168.1.1 to the 10.0.0.1 address.
It causes a double nat.
