MauricePratt
Dec 23, 2022Aspirant
MR60 signal dropouts on Wifi
I have a home office with a cabled connection to the modem as well as a MR60 with 2 satellites. My family have been reporting that they are losing the wifi signal at times even though I am not having...
Dec 23, 2022Guru - Experienced User
what channel do you have set on the 5ghz?
Make sure its not a DFS channel as that requires switching off of it if there's a signal detected on it and case a quick drop.
Why not have 2.4ghz enabled?
MauricePratt
Jan 01, 2023Aspirant
Thanks for taking an interest in resolving my wifi problem.
It is using channels 153 & 2. How do I know if it is a DFS channel?
2.4G is enabled. I just couldn't see it on my mobile. I can see if on the Nighthawk app
