NoVaJB
May 08, 2022Aspirant
MR60 slow LAN speeds by over 60%
I'm not sure when this started but I'm on firmware 1.1.6.122 and speed tests on wired LAN is about 63% slower than when I plug directly into my Fios router. When plugged into the MR60 I'm getting app...
NoVaJB
May 09, 2022Aspirant
For context, the first speed test is direct into the Fios router, the second is the same cable plugged into the MR60 LAN port. It wasn't always slow, I'm assuming a firmware upgrade is causing this.
May 09, 2022Guru - Experienced User
Make sure on the MR60 that you have access control, traffic monitoring, qos, and parental controls disabled, then reboot it and try.
Is the fios router in router mode or passthrough mode?
