Jimb9999
Apr 10, 2021Aspirant
MR60 slow WiFi speed
I purchased the MR60 and satellite in November and was happy with the performance now it seems if I am close to the router it works fine if I move away the speed test drops if I have the satellite con...
Apr 10, 2021Guru - Experienced User
have you tried moving the satellite around?
Certain materials do block wifi and maybe something was moved to cause obstruction
- Jimb9999Apr 10, 2021AspirantI have moved it to multiple locations and it doesn’t change, I have reset both to factory default and it hasn’t changed.
