Jimb9999
Apr 10, 2021Aspirant
MR60 slow WiFi speed
I purchased the MR60 and satellite in November and was happy with the performance now it seems if I am close to the router it works fine if I move away the speed test drops if I have the satellite con...
Jimb9999
I have moved it to multiple locations and it doesn’t change, I have reset both to factory default and it hasn’t changed.
Apr 10, 2021Guru - Experienced User
after changing firmware did you reset to factory?
What modem are you using?
- Jimb9999Apr 10, 2021AspirantNo I did a factory reset then did firmware on satellite then router. I am using an Arris TM822 modem.
- plemansApr 11, 2021Guru - Experienced User
"Then did firmware"
updated it?
Try downgrading, then factory reset, then reinstall. Try it without the satellite first.
- Jimb9999Apr 11, 2021AspirantI have done both downgraded and upgraded firmware, I have tried factory reset before and after. I have also tried it with the satellite and without the satellite and have had the same results. If I run test wired to the router speed Is fine. It is the WiFi that is horrible, I am getting 115 MPs wired and between 2.3-26 wireless.
