kane808
Jun 06, 2023Follower
MR60 Slow WIFI
OK, I have been having some speed trouble with my Surface Pro 7 that I do 99% of all my work on. I ran a quick google speed test and discovered I'm only getting 80mbps up and down. The Setup. I hav...
Jun 06, 2023Guru - Experienced User
What speeds do you see with both wired and wireless devices connected to the MR with the MS turned OFF?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model# of the LAN switch between the MR and MS?
Be sure your using a good quality LAN cable between the MR, Switch and MS. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR📡 and MS🛰️ to begin with depending upon building materials when wirelessly connected.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Smart Parental Controls or Circle, Traffic Meter.
Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
