Tadcrazio
Nov 14, 2022Aspirant
MR60 slows down and drops connections frequently
I have an ATT FIber modem/router (BGW210-700 ) with 1000mbps download speed that I have had no issues with whatsoever. I recently got an MR60 for more control of my network and having some issues. ...
Nov 14, 2022Guru - Experienced User
Be sure your using the IP pass thru on the ISP modem for the MR. You might set a IP address reservation for the IP address the MR gets from the ISP modem ON the modem.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR and MS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Tadcrazio
V.1.1.7.132
I have pass-through enabled. have not tried reservation
Cat6 is the cable i am using
1700 sqft
What is the distance between the router and satellite
40-45 feet roughly. pretty direct line of sight.
2.4 is auto. 5 is 152, can try a lower channel.
1 or 2 neighbors pop up but they are hundred's of feet away.
- FURRYe38Nov 14, 2022Guru - Experienced User
How many MS do you have deployed?
Does the problem appear if you turn OFF all MS units?- TadcrazioNov 14, 2022Aspirant
I only have one satellite, i can try disconnecting it and seeing it the problem persists.
Try that.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update?
