CarrieF
Feb 26, 2023Aspirant
MR60 solid amber light and no Wifi
Hi all, I encountered a sudden problem last night with my MR60 mesh router (2 satellites). I was clued into something happening because my Sonos music system stopped playing abruptly, and ESET start...
- Sep 05, 2023
Please post a copy and paste of the modems event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-routerOther items on the cable connections page look ok for the modem.
What Firmware version is currently loaded on the MK system?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What is the size of your home? Sq Ft?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR📡 and MS🛰️ to begin with depending upon building materials when wirelessly connected.Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON therouter and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
CarrieF
Sep 03, 2023Aspirant
Good day!
I posted earlier this year about a problem which may or may not be related to my current one, which just began on Thursday. (Prior post: https://community.netgear.com/t5/Nighthawk-Wi-Fi-6-AX-Mesh/MR60-solid-amber-light-and-no-Wifi/m-p/2297216#M226866)
SETUP: Netgear CM1100 modem connected to desktop computer and Netgear MK63 Wifi-Mesh router system. MR60 router is next to modem in same room as desktop; two MS60 satellites are in separate rooms, approximately 15' and 45' away, all on the first floor. Wifi typically accommodates my work laptop, work iPhone, personal Android cell, personal Samsung tablet, HP printer, and Sonos music system. Since prior issue in February, Wifi has been working relatively well, with the sole exception of occasionally seeing much lower download speeds in room with the router than in room next door (which has a satellite).
CURRENT PROBLEM: Wifi abruptly stopped Thursday afternoon. Router shows solid Amber light; devices showed "connected, no internet". Ethernet connection to desktop computer works fine.
WHAT I'VE DONE:
1. Power-cycled router twice, then power-cycled modem separately, then power-cycled both of them together at least 3 times. No change.
2. Factory reset of modem and router. No change.
WHAT I HAVEN'T YET DONE:
1. Update firmware manually. I have downloaded the necessary files but will note the firmware version on the router is current when I was able to check it on Friday.
2. Cleared event logs. I have attached the modem's event log page but have yet to clear it.
POTENTIAL CLUE? When I hooked up my work laptop directly to the modem (basically unplugged the cable that had gone from my desktop to the modem and plugged the computer end into the work laptop's dock), I cannot connect to the internet. I got a message saying there was no valid IP address. I cannot rule out the possibility that there is an issue with either the ethernet adapter on that laptop or the dock somehow, though. (Dell Precision M5560 with Thunderbird dock)
Attached is the event log from the modem I will attach the cable connection info in separate posts, since it seems to limit me to one attachment per post. Any ideas? At this point, I can't even confidently say whether it's the modem or the router that has the problem.
Thank you for any assistance you can think of!
Carrie
