unicanuslupus
Dec 23, 2021Aspirant
MR60 Span Port
Is there a way to set up port mirroring/span port for an MR60 Router? Thank you Unicanuslupus
Dec 23, 2021Guru - Experienced User
Might check the user manual for this feature, if not seen then probably not supported on the MK series of routers.
unicanuslupus
That was the first step I took. Propably should have mentioned that above.
