RockstahStatus
Nov 03, 2022Aspirant
MR60 Stopped allowing IoT devices from connecting
Hi. 2 weeks ago I woke up one morning and all of a sudden non of my lights or tvs or anything I has connected to Alexa was working. It took me 3 days to realize that every time I tried to reset it wi...
Nov 04, 2022Guru - Experienced User
1. what firmware is on the mr60 and its satellites?
2. what modem/gateway is the router connected to?
You can use the RAX in conjunction with the MR device.
Just go RAX (route rmode)---->MR (in access point mode)
RockstahStatus
Nov 08, 2022Aspirant
I tried to do this. I'm not completely sure I was doing it right. So I first reset the RAX and made the network with that. I then Unplugged the network the ethernet from the RAX and then put it into the MR where I then started it in AP Mode. But then I couldn't figure out how to connect it to the network from the RAX. So right now I have it wired to the RAX. I wanted everything to be on the same network so I read in a forum to just use the same network name but change the channel of the 2.4g.
The issue now is some Things will connect to the 5G network. but anything still trying to get on the 2.4 can't.
