Nighthawk_25's avatar
Nighthawk_25
MR60 stopped working
Hi all, Everything was fine yesterday, today have a white flashing light on the router. Have tried resetting it no effect. It’s 15 months old. Not had a problem with it before. Have internet ...
  • FURRYe38's avatar
    Nov 16, 2022
    Can you access the MRs web page at all with a wired PC?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
