Nighthawk_25
Nov 16, 2022Aspirant
MR60 stopped working
Hi all, Everything was fine yesterday, today have a white flashing light on the router. Have tried resetting it no effect. It’s 15 months old. Not had a problem with it before. Have internet ...
- Nov 16, 2022
Can you access the MRs web page at all with a wired PC?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Nighthawk_25
Thanks.
A third reset stopped the white light flashing.
All went blue, great, but nothing actually connected to the internet. Went through the setup and still the same.
Walked away for 10 mins and it prompted me to set up again and all is back working.
Seems to be connecting again now.
Thanks for the help.
Nov 16, 2022Guru - Experienced User
Was the system auto FW updated or did you manually update FW?
Good to hear.
Enjoy. 📡
