Fuzzyfrog
May 02, 2026Follower
MR60 will not connect with 2 satellites
I have had this router for at least 5 years. We got it because we have a TV in a guest house next to our house. The satellites worked fine when we first got them but we don't use the TV very much s...
CrimpOn
May 02, 2026Guru - Experienced User
Since new firmware was released in Oct, 2025, this might be a good time to "refresh" the entire system.
i.e. Download the new firmware from the support web site to a computer
https://kb.netgear.com/000070298
Extract the firmware for the router and satellites from the zip files.
Place both the router and both satellites in the same room and do a Factory Reset on all three units.
Power them up and see if the satellites connect to the router.
Then, attempt to install the new firmware using the router web interface (or the Nighthawk app).
