meatball2121
Apr 19, 2022Tutor
MR60 Wireless Mesh Router issues with netflix and unblocker or proxy issue
Hello I have the MR60 Wireless Mesh Router issues with Netflix and unblocker or proxy issue. Every time I try to watch some shows on Netflix I keep getting the you seem to be using an unblocker or pr...
Apr 19, 2022Guru - Experienced User
1. what modem/gateway do you have from spectrum?
2. what firmware is on the mr60?
3. are you using netgear armor?
4. is it on all netflix devices or just the one?
- meatball2121Apr 19, 2022Tutor1. what modem/gateway do you have from spectrum? E31U2V1 see attachment
2. what firmware is on the mr60? The latest fiware
3. are you using netgear armor? No
4. is it on all netflix devices or just the one? All devices that are connected to my netgear wi-fi, works fine when connected to phone data.- plemansApr 19, 2022Guru - Experienced User
"the latest" doesn't help as it changes. And sometimes it isn't the latest.
What version is on the router and on the satellites?
Do you have IPv6 enabled?
Are you using your own or a different DNS service?
- meatball2121Apr 19, 2022TutorDo you have IPv6 enabled? Nope it's disabled
Are you using your own or a different DNS service? I am using Spectrims modum and Spectrum cable internet service.
Will get the other answers when I get home
