meatball2121
Apr 19, 2022Tutor
MR60 Wireless Mesh Router issues with netflix and unblocker or proxy issue
Hello I have the MR60 Wireless Mesh Router issues with Netflix and unblocker or proxy issue. Every time I try to watch some shows on Netflix I keep getting the you seem to be using an unblocker or pr...
meatball2121
Apr 19, 2022Tutor
Do you have IPv6 enabled? Nope it's disabled
Are you using your own or a different DNS service? I am using Spectrims modum and Spectrum cable internet service.
Will get the other answers when I get home
Apr 19, 2022Guru - Experienced User
Try enabling IPv6
Also, the DNS isn't your modem/gateway.
https://kb.netgear.com/30510/How-do-I-set-static-Domain-Name-System-servers-on-my-NETGEAR-router
The stock settings use your ISP's dns server. You can change it to use ones like googles or cloudfare. You can try that option.
