Rustonka
Mar 24, 2022Guide
MR60 Wireless Mesh Router
Windows 10 My MR60 stopped connecting to the internet when the electricity went out and would not come back on line. At the time Spectrum was my service provider. I tried turning everything off and ...
- Mar 31, 2022
If you got it up and working, you might mark it solved so others aren't still trying to fix the issue.
Glad you got it working!
Mar 26, 2022Guru - Experienced User
the arris gateway isn't a modem only device. Its a modem/router combo device and causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
Rustonka
Mar 26, 2022Guide
Also, I disconnected the Arris when I tried to connect the MR60. I was connecting directly to the Nokia modem.
- EternalStudentMar 29, 2022Apprentice
I'd log in to the router's admin page and see what it says. Can it get an IP address? If not I'd call Ziply (or whoever your currently internet ISP is) for support.
Another step is to remove the router from the chain, and just get internet working without it. Plug a computer into the modem directly if possible.
- RustonkaMar 30, 2022Guide
Thanks for your reply. The Ziply tech did try to get the router to work and was not able to.
Connecting directly to the modem would work for my computer but not for any of my other devices.
- plemansMar 30, 2022Guru - Experienced User
again, the arris is a modem/router combo device.
Try this.
factory reset both the arris and the netgear.
Then bootup/install the arris.
Leave the netgear disconnected from the arris.
Hardwire a pc/laptop directly into the netgear and use that to start the install process.
Leave it disconnected from the arris the whole time. Once through setup, then put it in access point mode.
Once its in access point mode, then connect it to the arris.
