Rustonka
Mar 24, 2022Guide
MR60 Wireless Mesh Router
Windows 10 My MR60 stopped connecting to the internet when the electricity went out and would not come back on line. At the time Spectrum was my service provider. I tried turning everything off and ...
- Mar 31, 2022
If you got it up and working, you might mark it solved so others aren't still trying to fix the issue.
Glad you got it working!
Rustonka
Mar 30, 2022Guide
Thank you all for your patience and help. I was finally able to reset the router a third time and got it to work directly connected to the Nokia modem.
Mar 31, 2022Guru - Experienced User
