forrest_fire1's avatar
Aug 12, 2022
MR60 wirelessly connect to mobile hotspot?
I can not find setting to tether to my mobile hotspot.
Is it possible? (I have no router)
  • plemans's avatar
    There isn't a way over wireless.
    Does your hotspot have an ethernet connection?
    what hotspot is it?
      • FURRYe38's avatar
        Might be able to configure AP mode on the MR then connect it to the mobile hot spots ethernet port.
  • FURRYe38's avatar
    If you have the Nighthawk MESH MR60 system, the MR requires a Ethernet connection from either a Cable, DSL modem or Fiber ONT ISP service device. It doesn't support wirelessly connecting to a wireless source.
    Does your hot spot have a ethernet port?
    • forrest_fire1's avatar
      forrest_fire1
      Yes, I've been using the ethernet port for years, but no longer have wired internet and therefore can't get internet to the MR60.
