jjgonzalezh
Nov 23, 2020Initiate
MR60 with blue light while MS60 with amber light
Good afternoon. After a recent power outage the mesh came back on but I noticed the router has a steady blue light while the satelites have a steady amber light. On the Netgear app Network Map, the r...
- Dec 01, 2020
Hello jjgonzalezh,
May you factory reset your Nighthawk Mesh system by holding down on the reset button for 15+ seconds using a pin/needle. You will need to run through the setup assistant again and you may do so using the Nighthawk app.
Regards,Christian
Christian_R
Dec 01, 2020NETGEAR Employee Retired
Hello jjgonzalezh,
Christian
- jjgonzalezhDec 10, 2020InitiateIt worked! Many thanks!!
