OldSteelBike
May 22, 2024Tutor
MR60 won't respond after a power outage
I’ve got a Nighthawk Mesh system with an MR-60 and two satellites. My cable modem connected to the MR-60 is a Netgear CM 400. My home suffered 12-hour-plus power interruption. Unlike prior power out...
- May 27, 2024
Last resort to try on the initial MR60 is a 30-30-30 reset to see if it might recover it. If that fails, glad the replacement is working.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
OldSteelBike
May 27, 2024Tutor
Again using a random product.
Just read my last reply as posted, and it looks nothing like the draft text. Really?
Short answer: The MR60 is bricked. A test replacement in the same setup worked fine, the MR60 in a different environment still could not be reached.
The power failure was a set of underground utility lines cut by a plumber, as a tree's roots moved them over 50 years.
A replacement unit is in and working fine now, and how I'm posting this message.
May 27, 2024Guru - Experienced User
Enjoy. 📡
