Porkybomb
Dec 03, 2022Follower
MR60, WPS with other routers
Hi so over the past day I have tried to set up a sort of mesh system with my r6700v2 to my MR60 router and satellites via WPS, and I'm not sure if it's connected or not (no speed difference.) so I am...
Dec 04, 2022Guru - Experienced User
Are you having issues connecting the MR60 to the R6700? Or adding satellites?
Your description doesn't tell us.
if the R6700 is the primary router, you'd want the mr60 in access point mode to avoid the double nat.
Or vice versa.
